SOLVED macOS Monterey not starting (bootloop)
Same effects. Still the same bootloop error with the same messages
Do I need to configure something (for example in config.plist) than just go and patch?
That's weird. What steps did you do this time?
Yes, the EFI should be preconfigured and then you just need to patch it. Or you can even make a whole new configuration on any old macOS version and generate the EFI using OCLP and then use it on the target OS.
Here is one of the references from the EliteMacx86 Channel.
How? The video doesn’t contains information about this.
About the EFI?
EFI is already supposed to be configured and the video demonstrates about patching Graphics kexts using OCLP.
About the EFI?
Is my EFI right?
Reinstalled again, and now it’s stuck on an infinity recovery os boot.
Rajala1404
