MinecraftW06
HP EliteBook Folio 9470m
Intel Core i5 3427U vPro
Intel HD Graphics 4000
12.0.x
  1. OpenCore
I installed macOS Monterey, installed HD4000Patch, and now it's not starting.
Intel HD 4000, i5 Ivy Bridge.
Last debug lines before restart:
#[EB|IRM:RMD]
#[EB|B:RB]
#[EB|WL] 0 0 0x01 0x41 6 0x0E
#[EB|REBOOT] 1
#[EB|LOG:RESET:RECOVERY] 2022-01-06T15:20:40
Attached full log file.
Linked EFI folder (it says too large to process): https://www.dropbox.com/s/i7aycwfhvchk1dr/EFI.zip?dl=0
  • opencore-2022-01-06-161904.txt
11.0.x
  1. OpenCore
#[EB|IRM:RMD]
#[EB|B:RB]
#[EB|REBOOT] 1
What patches did you choose?
MinecraftW06
12.0.x
  1. OpenCore
Only this: https://github.com/chris1111/Patch-HD4000-Monterey
And I configured the plist and os as it says:
  • To use this program SIP security (Fully disable) csrutil disable csrutil authenticated-root disable
  • Gatekeeper must be disabled
  • OpenCore config setup: NVRAM ➤ Add ➤ boot-args ⬇︎
  • -v keepsyms=1 -lilubetaall amfi_get_out_of_my_way=1 -no_compat_check
  • csr-active-config ☞ EF0F0000
  • PlatformInfo ➤ MacBookPro12,1
11.0.x
  1. OpenCore
Use OCLP instead.
MinecraftW06
12.0.x
  1. OpenCore
11.0.x
  1. OpenCore
MinecraftW06
12.0.x
  1. OpenCore
OpenCore Legacy Patcher? OK, but later. I will get home about 7 hours later and a reinstall is also needed.
It is still installing, but I have a question. What patches should I apply?
11.0.x
  1. OpenCore
Only Graphics. As you're able to boot the installer using your EFI. So, only patching System should be required.
MinecraftW06
12.0.x
  1. OpenCore
It says model not supported by patcher. Model is MacBookPro11,4. What should I do? Or can I dismiss it and still apply the patch?
MinecraftW06
12.0.x
  1. OpenCore
Is this the patch system volume / volume patch option?
Similar threads
Thread starter Title Forum Replies Date
EliteMacx86 GUIDE PCI Device Implementation on macOS General 0
Similar threads
OmegaRed1723
