SOLVED macOS Monterey not starting (bootloop)
Kernel
Dell G15 5510
Intel Core i7-10870H
Intel UHD Graphics 630
I installed macOS Monterey, installed HD4000Patch, and now it's not starting.
Intel HD 4000, i5 Ivy Bridge.
Last debug lines before restart:
#[EB|IRM:RMD]
#[EB|B:RB]
#[EB|WL] 0 0 0x01 0x41 6 0x0E
#[EB|REBOOT] 1
#[EB|LOG:RESET:RECOVERY] 2022-01-06T15:20:40
Attached full log file.
Linked EFI folder (it says too large to process): https://www.dropbox.com/s/i7aycwfhvchk1dr/EFI.zip?dl=0
#[EB|IRM:RMD]
#[EB|B:RB]
#[EB|REBOOT] 1
What patches did you choose?
Only this: https://github.com/chris1111/Patch-HD4000-Monterey
And I configured the plist and os as it says:
  • To use this program SIP security (Fully disable) csrutil disable csrutil authenticated-root disable
  • Gatekeeper must be disabled
  • OpenCore config setup: NVRAM ➤ Add ➤ boot-args ⬇︎
  • -v keepsyms=1 -lilubetaall amfi_get_out_of_my_way=1 -no_compat_check
  • csr-active-config ☞ EF0F0000
  • PlatformInfo ➤ MacBookPro12,1
Use OCLP instead.
OpenCore Legacy Patcher? OK, but later. I will get home about 7 hours later and a reinstall is also needed.
It is still installing, but I have a question. What patches should I apply?
Only Graphics. As you're able to boot the installer using your EFI. So, only patching System should be required.
It says model not supported by patcher. Model is MacBookPro11,4. What should I do? Or can I dismiss it and still apply the patch?
Is this the patch system volume / volume patch option?
ryusuke17
