SOLVED AMD 6800 XT lag/stuttering with Topaz GP AI
I tried the shanee pat patch and disabled algrey pat patch.
Still the same issue.
Declutter your configuration first.
Also, provide your BIOS Settings.
Ok. Will clean up , test and get back to you.
Thanks for your help so far.
I cleaned up the config.plist.
Did not make any difference.
Dortania guide says Whatevergreen kext is required. but if i add it , i get black screen. I removed whatevergreen kext and its all normal again.
I m guessing its a issue with the Topaz app.
Anyway to limit the GPU Usage? Not cpu usage. I tried limiting CPU usage using app police. But that only allows to limit CPU. Limiting CPU usage also did not make any difference.
I need to somehow limit GPU Usage and see if that makes any difference.
No PR files attached.
attached cleaned up config.plist
Incomplete PR Files attached.
- IOReg is missing
- ACPI Tableset is missing
- BIOS Settings is missing
I got the latest build of the topaz and i could not run it on my AMD hackintosh.It was crashing.
More digging and found out i needed amdfriend. Ran amdfriend on topaz app and patched it and then the app started working.
In the latest build , the topaz app works perfectly in GPU and CPU mode. No lag or stuttering.
I was using an older build of topaz , because of certain features.
so the issue is with the older build of the app. Its buggy.
This issue can be closed.
Thanks for your help.
raymondleung416
