Gigabyte Z590 Vision D - i9 11900K - Asus Radeon RX 6600 XT with EFI
Absolutely. Read Step #4.
Didn't works for me.
Here is my EFI for now.
How configure Thunderbolt on my mobo?
Thunderbolt 4 USB Controller [Maple Ridge 4C 2020]:
Type: USB controller
Driver Installed: Yes
MSI: Yes
Bus: PCI
Slot: Internal@0,28,4/0,0/2,0/0,0
Vendor ID: 0x8086
Device ID: 0x1138
Revision ID: 0x0000
Link Width: x4
Link Speed: 2.5 GT/s
It doesn't work because you have "HideAuxiliary" set to True. When this option is Enabled, you need to press the "Space Bar Key" on your Keyboard to show all the other options in the picker.
Hello. How can I archive this? With HideAuxiliary enabled I have all those options in picker menus. How can I hide one record?
Which entry do you want to hide?
Hi guys! what with KC3000 now, after month? no kernel panic or another issues? in one different place one man wrote that his KC3000 random panic and he replaced it to WD SN850.
Do NOT hijack the threads.
Hello. I have problems with a wired network. My lan cards are not working. Is there any chance of bringing them alive?
No PR files attached.
Hi. I need some guru help.
I am planning to upgrade my video card. The price for 6900xt is the same as 7900xt.
So, I think. Can I use two video cards in my setup? One for Windows purposes (RX7900XT) and the other for macOS? I am thinking about Asus RX550 4Gb for macOS.
Here are my slots:
  1. 1 złącze PCI Express x16, x16 (PCIEX16)
  2. 1 złącze PCI Express x16, x8 (PCIEX8)
    * The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot operates at up to x8 mode.
    (The PCIEX16 and PCIEX8 slots conform to PCI Express 4.0 standard.)*
    * Supported by 11th Generation processors only.
  3. 1 złącze PCI Express x16, x4 (PCIEX4)
    * The PCIEX4 slot shares bandwidth with the M2P_SB connector. The PCIEX4 slot operates at up to x2 mode when a PCIe SSD is installed in the M2P_SB connector.
  4. 1 x PCI Express x1 slot
    (The PCIEX4 and PCI Express x1 slots conform to PCI Express 3.0 standard.)
BTW - I am using 3 NVMe SSD. One PCIx4 and two PCIx3.
Can I use RX550 in Slot #4?
wojko
