SOLVED Dell Inspiron 15R SE ( 7520) Monterey Post Installation
in a past reply , you have mentioned about "go through the documentation and patch the XML to support your codec" .
Can you explain it?
Note that previously you might not have been able to get Audio as almost every Dell System requires IRQ Conflicts patching.
I didn't done the Patching of DSDT's .
should i do it ?
Yes, it's recommended for Laptops.
in the stage of preparing EFI for my Hackintosh, you told me to skip it for that time. Please refer the attachments.
So now i don't have any patches in the ACPI->Patch .
ACPI Renames are a different thing. It's not needed.
should i do it ?
is it necessary to use ACPI-> Patch "Rename GFX0 to IGPU (Graphics)" ?
will it increase the intel HD 4000's performance ?
You asked me to skip it at the preparation stage of EFI.
Forgive me for asking several questions each are different scopes.
When i'm checking your guides again , i found that you have mentioned as per attached.
( DGPU can only work on Laptops if it meets the requirements listed below.
  • Compatible DGPU
  • Intel GPU must be factory disabled. )
Is there a separate guide to do this? So i can use my DGPU AMD RADEON HD 7730M ?
That's right. In your case, Intel GPU is enabled.
No, it's automatically done via WEG.
GFX0 to IGPU enables IGPU PM. However, this is automatically done via WEG and is not required.
I will try it now. Ask you, if any help needed.
Should i do the IRQ Conflicts patching also with the above "Adding-codec-support" ?
It's done automatically when patching DSDT and SSDTs.
Yes, but is there any way to factory disable the intel GPU and use the DGPU instead?
I see , you have edited my post title. now the title is very suitable for this discussion. (y)
ilikeeatingpeeandpoo
