No, it's done when designing the logic board.Yes, but is there any way to factory disable the intel GPU and use the DGPU instead?
It has been split from your previous thread as the original issue was solved. If you want to see your old thread, refer to the link below.I see , you have edited my post title. now the title is very suitable for this discussion.![]()
SOLVED - Intel HD4000 macOS Monterey 12.6 - Laptop's internal display not working, External monitor is working - Dell inspiron 15R SE ( 7520)
Dear Admin, I hackintoshed my Dell laptop inpiron 15R SE (7520) with macos Monterey 12.6 from Olarilla's website. After the installation of Monterey 12.6 , initially my system detected only 4MB of VGA of INTEL HD 4000. Therefore i installed the application...
elitemacx86.com
