SOLVED Dell Inspiron 15R SE ( 7520) Monterey Post Installation
Yes, but is there any way to factory disable the intel GPU and use the DGPU instead?
No, it's done when designing the logic board.
I see , you have edited my post title. now the title is very suitable for this discussion. (y)
It has been split from your previous thread as the original issue was solved. If you want to see your old thread, refer to the link below.
ok.☹️:cry:
Noted
No, it's automatically done via WEG.
GFX0 to IGPU enables IGPU PM. However, this is automatically done via WEG and is not required.
Understood
Now you should consider patching the DSDT and SSDT first and then proceed with the rest of the Post Installation task.
Reactions: abdulahath
No, OpenCore has a different process that is not documented on this forum yet. Will be documented soon. In the meantime, you can use Clover Bootloader to extract the native ACPI Files.
I'm not familiar with Clover.
How can i do this?
"To begin with the process of extraction, make sure the Clover bootloader has been installed either on your installation USB or the system drive. If you haven't installed it, make sure to install it." ?
And also please advise
Which order should i do the below tasks?
1. https://elitemacx86.com/threads/how-to-patch-laptop-dsdt-and-ssdts.178/
2. https://github.com/acidanthera/AppleALC/wiki/Adding-codec-support
I needed the xcode version 13.3.1 , therefore i cannot stick with Big Sur. Regarding Graphics acceleration, after OCLP patch it's usable for me.
i disagree with your second statement. Admin has requested me to use OCLP and it's done the purpose.
ahh ok, if full hardware graphics acceleration is not required then well done on getting Monterey working
ok. I'll keep you posted.(y)
How can i do this?
Before proceeding, make a backup of your configuration and transfer it to any USB Flash Drive. Remove the OC Configuration from your ESP and then proceed with the Clover installation. Note that you don't need to configure the config.plist to extract the ACPI Tables.
Patching the DSDT and SSDTs first. Just skip the Layout ID patch for now.
Without the Graphics acceleration, the whole system is so slow, with random freezes and artifacts. The performance is nearly similar to Virtual Box and VMware.
ambruhidot
