Post installation problem which are unable to be fixed in macOS Sonoma!!!
Now i am making my own EFI for macOS Sequoia and i got this MACH REBOOT error i am attaching my EFI tell me the problems in my own made EFI via google drive here as its not uploading in your site due to file size exceed problem and this problem has and need to be fixed and btw i also have my audio codec with me but where to put in tell me that also and i am sharing my iGPU VRAM details also
Your config.plist is not as per the guide. Problems are expected. Here are a few issues listed below. Make the following changes to your config.plist:
- Why are you using SSDT-HV-CPU.aml? Its intended for Hyper-V virtualization platforms, not bare metal.
- Why are you using SSDT-CPUR and SSDT-PLUG-ALT together? Use the former one. If it doesn't work, try the latter one.
- SSDT-PMC shouldn't be required in your case unless the native NVRAM is borked.
- Why are you using EnableWriteProtector and RebuildAppleMemoryMap together? Use the latter one.
- Seems like you're still not aware what hardware your Laptop consists of and you're injecting kexts blindly. You should NOT inject bunch of kexts that's not intended for your hardware. Remove the SMC kexts except for VSMC. If your hardware isn't using USB based Audio, then you shouldn't inject AppleALCU. VoodooRMI shouldn't be required in your case. Devices can be fixed later during the post install phase. The goal is to have the minimal amount of kexts that are mandatory to boot the macOS installer and not use additional kexts to avoid conflicts. Therefore, remove the WiFi and Bluetooth related kexts. dSYM related extensions shouldn't be injected as well. As your hardware is not HP, LapicKernelPanic shouldn't be required in your case. Moreover, the kexts are not in sorted order. You should use NootedRed instead of WEG.
- Does your Laptop has option for Resize BAR and 4G Decoding? If yes, remove the npci flag.
- UnblockFsConnect is generally required by HP systems.
TAKEKamikaze
