SOLVED Dell Inspiron 15R SE ( 7520) Monterey Post Installation
i
I used the 2nd method and My hackintosh is much speedier.
Attached the Geekbench before and after of PM.
Thanks for your help.
It seems like CPU PM is working now and the scores are more than Windows ;)
Did you test the SSD speed?
Glad it boosted the CPU performance to best :love:
Yes, But it's a bit strange.BlackMagic Speed test , with the 1GB Stress it's perform well and with the 5GB Stress Write speed decreased suddenly below 100Mbps :unsure:😰
Any suggestions?
is there any way for further boost the Intel HD 4000's acceleration/performance?
as per my understanding, I can't add support for my dGpu AMD Radeon HD 7730M. Is it true? is there anyway i can use it ?
Glad to hear that!
Any suggestions?
That's normal. Test using the default settings.
No, unfortunately, you cannot do that. Everything is handled via Apple's packaged driver.
Yes, that's right. For dGPU to work on Laptops, the IGPU must be factory disabled. Optimus and Switching Technology isn't supported on Non-Apple computers when using macOS/OS X.
For a ivybridge Laptop hackintosh, my current performance is more than satisfactory (y).
There's 2 thing i didn't tried yet.
1. Enabling Audio "conexant CX20672-21Z" ( the AppleALC is not working with the id's 3,12,13,14,28.) - so i'm going to try the voodooHDA now.
2. Enabling Bluetooth
Oh, in that case, you have two options. The first is to use VoodooHDA, which is not recommended but easy. The second is to go through the documentation and patch the XML to support your codec.
in a past reply , you have mentioned about "go through the documentation and patch the XML to support your codec" .
Can you explain it?
I didn't done the Patching of DSDT's .
should i do it ?
in the stage of preparing EFI for my Hackintosh, you told me to skip it for that time. Please refer the attachments.
So now i don't have any patches in the ACPI->Patch .
Forgive me for asking several questions each are different scopes.
When i'm checking your guides again , i found that you have mentioned as per attached.
( DGPU can only work on Laptops if it meets the requirements listed below.
  • Compatible DGPU
  • Intel GPU must be factory disabled. )
Is there a separate guide to do this? So i can use my DGPU AMD RADEON HD 7730M ?
gopon_user
