Only if the IGPU is factory disabled.Will it support GeForce GT 750M?
No PR files attached.GTX 960 worked in macOS Big Sur of AMD Hackintosh but full acceleration did not work. OpenGL did not work, Pease can you help me?
The patch is completely experimental and is not meant for the production environment.It gets stuck on reboot on IOConsoleUsers after applying the patch. I don't have iGPU only nvidia. Can anything be done?
Is this enough? Sorry for taking so long to respondThe patch is completely experimental and is not meant for the production environment.
Attach your PR files to check further.
Here is my EFI tooIs this enough? Sorry for taking so long to respond
Your configuration is not as per the guide.Here is my EFI too
elitemacx86.com
