Hi,
Is the following Nvidia Cards supported ? :
1- NVIDIA Quadro M1000M 2GB
2-NVIDIA Quadro M2000M 4GB
3-NVIDIA Quadro M1200 4GB
4-NVIDIA Quadro M2200 4GB
note : All previous cards are integrated with HP Zbook workstation Laptop .
Thanks
Can be used with WebDrivers. However, IGPU must be factory disabled as per the requirements.
unable to build new kernel cache Venture Beta 11
thanks
this boot flag ipc_control_port_options=0 Steam working
Can you elaborate more so that I can update the guide?
Adding this to boot arg, fixes the cache building for Ventura?
only monterey test
only monterey test
So, adding that boot flag makes this work on macOS Monterey? Note that Monterey already works without this bootflag. With SIP disabled.
this is required for steam to work
Alisson de Santana
