Will it support GeForce GT 750M?
GTX 960 worked in macOS Big Sur of AMD Hackintosh but full acceleration did not work. OpenGL did not work, Pease can you help me?
No PR files attached.
It gets stuck on reboot on IOConsoleUsers after applying the patch. I don't have iGPU only nvidia. Can anything be done?
The patch is completely experimental and is not meant for the production environment.
Attach your PR files to check further.
Is this enough? Sorry for taking so long to respond
Here is my EFI too
Hi,
Is the following Nvidia Cards supported ? :
1- NVIDIA Quadro M1000M 2GB
2-NVIDIA Quadro M2000M 4GB
3-NVIDIA Quadro M1200 4GB
4-NVIDIA Quadro M2200 4GB
note : All previous cards are integrated with HP Zbook workstation Laptop .
Thanks
Alisson de Santana
