My PC configuration: i7 11700, GPU 1050, no iGPU, I have followed the instructions but only black screen appears after patching by Opencore lagency Patch, I have tried reinstalling many times, still the same, please help me
No PR files attached.
I have followed these steps, and I am getting a transparent dock after rebooting, but the issue is that my graphic card size is still 8 MB. I'm using
GT 1030
Intel Core i5-3470
macOS monterey 12.3
hi , i have follow these steps .
when i restart after Post-Install Root Patch , my monitor receive no signal (black screen)
install on Monterey 12.4
my GPU GTX 1060
CPU : i7-3770K
GT 1030
Intel Core i5-3470
macOS monterey 12.3
my GPU GTX 1060
CPU : i7-3770K
I'm not sure what you mean. Should I remove these dictionaries ?
I thought that it might be the OS version, so I tried to update Monterey to 13.5 and it is still not working.
PR files mean Problem Reporting Files. You need to attach EFI, Kextcache output, IOReg and Hackintool PCIe export.
Reactions: abdulrahman.ali19
Here are all the required files. I have also added the last opencore logs to EFI.zip, in case they might be helpful.
- OpenCore is outdated.
- Boot arg for enabling Web Driver is missing.
fly.gao
