Is it possible to run Ventura with dGPU (NVIDIA GT650M) on a MacBook Pro mid 2014 (13,3 it should be) and is it fully supported?
For real Macs, OCLP is the way. This thread is dedicated for non-Apple computers only.
Hello, I recently clean installed ventura and I was using catalina prior to this. My issue is that the display is unknown and reso is only 1920 × 1080. My specs:
CORE i5-9400 9TH GEN COFFEE LAKE
GIGABYTE H310M-H
16 GB RAM
NVIDIA GT 710
I tried to follow your steps but can't install web drivers. It was saying unsupported for OSX 13.3 with that issue I can't complete your how-to-enable-nvidia-graphics-on-macos-clover-opencore guide and follow the steps on this thread. Your input would be highly appreciated.
GIGABYTE H310M-H
16 GB RAM
NVIDIA GT 710
You don't need to install Web Drivers. OCLP will do that for you. Read the guide again.
I have successfully made the system to recognize the NVIDIA GT 710 but somehow a lot of the features won't work. Take for example I cannot open or make skype, steam or ringcentral to run. The improvement is that I can now change the resolution and the pc works fine. Are the capabilities of the VC really limited even to the extent that it can't open skype or RingCentral?
Can this work with a EGPU and m3 ? Or m2?
can it work in Mac Pro
A fix needs to be applied for Skype.
eGPU will not work for Apple Silicon. Intel Macs will work.
thank you so much! Thanks to your tutorial I was able to install mac os I was able to install mac os monterey on my alienware 15 r4 with a gtx 1080 because it does not have a mux or nvidia optimus chip. According to the diagram, the graphics card is connected via PCIe to the processor. The system is relatively efficient. The problem is that when I open final cut, the program closes and the error window appears and when I open Photoshop or any program that requires power from the video card, it renders as if it didn't have it. Is there any solution for it? 427897828_10160726876612626_2206435104249041616_n.jpg
mykal
