i got a black screen on my system
How do I bypass the incompatibility issue for webdriver installer on BigSur?
Following this guide
Should I proceed without installing the webdrivers?
There is no WebDriver since macOS Mojave and it cannot be installed on macOS Mojave and newer. However, compatible NVIDIA Graphics Cards (Upto Pascal Series) can be used on macOS Mojave and newer using the experimental patch.
Ya, I understood it later that I need to use OLCP directly. GT 1030 worked on Monterey with the patch.
Thanks!
I followed the guide, I used OCLP 0.5.0 for my gtx650 video card but the top bar and dock are not transparent. It seems that even with OCLP the video acceleration is not being activated. what can i do to solve it?
No PR files attached.
Can I patch the laptop's pascal GPU?
On Laptops, it's different due to the technology. If the IGPU is factory disabled, you can use it with acceleration. However, note that this patch is still experimental.
khoi
