Why do you keep trying to identify my Mac as a desktop. This is definitely a laptop because it has an LVDS and with ID 00001B59 it boots correctly and the video accelerator works.
Although I may be wrong and its really laptop ID need...
As mentioned before, the determination is based on CPU, not the LVDS port.
- Remove the BrcmPatchRAM3.kext. Your system has Intel WiFi, not Broadcom.
- WhateverGreen.kext should load after VirtualSMC.kext
All done. But ID 00001259 still no luck
I went a little further and turned on HDMI. Well LVDS now not work. I am attaching the config
I changed FB0 type from 0004 to 0200
By the way, current HDMI output have a problem - very very purple screen (checked on two different monitors) IMG_1979.jpeg
J.An
