By the way, current HDMI output have a problem - very very purple screen (checked on two different monitors)View attachment 4944
Pink screen is normal if you mismatch the connector type, which you obviously did.
Define con0, con1 and con2.
con0 = 00040000
con1 = 00080000
con2 = 00080000
Problem with PURPLE solved with config:
Now HDMI - good, LVDS - black screen
It is usually not likely, but this can mean that in your system, con0 is responding to HDMI and con1/con2 should be LVDS.
In that case,
con0 = 00080000
con1 = 00040000
con2 = 00040000
In that case,
con0 = 00080000
con1 = 00040000
con2 = 00040000
Really HDMI is "Con0"
Unfortually, LVDS screen still off.
I was trying all possible values of each connector (Con1, Con2 and even Con3)
Display Port00 04 00 00
  • Display capable Type-C ports are DP internally
HDMI00 08 00 00
DVI (Dual Link)04 00 00 00
DVI (Single Link)00 02 00 00
VGA10 00 00 00and even VGA))
but no luck
Next step - searching right Bus ID ?
HDMI00 08 00 00
but no luck
Yes, Bus ID patching should bring the LVDS display.
Hi everyone, tell me pliz where to turn the OS, the story is this: Monterey works, but when I switch to a fresh OS, I get a reboot, I want to install Ventura, so I disguise myself as a cabileak (I have a skylake)
No PR files attached.
Similar threads
mykal
