Attached PR files.
It's a fun learning project,
the board is Supermicro X9SCA-F rev 1.01 with LSI 2008 SAS controller (old server)
I managed to install Monterey and got it running with Nvidia GT640 with OCLP patch, but was looking for something low profile as the case is low, hence this AMD R5 430 GPU. Seems like it will not work that well. Have a look, maybe you can suggest something. Thank you!
Attached PR files.
PR Files are missing.
Edited the post with PR files
I can't get this card
0x675b
I put 13.6 and above
R7/R9 cards are supported. Never tried an R5 and it may not be supported. What's the Device ID?
0x675b
Your profile shows you have HD7670. Is that what you're trying to make it work?
675B seems like an OEM card. You need to inject 6758 Device ID and it should work. If it doesn't, you may need to use OCLP to patch as the support may have removed. Check on HS first.
AMD GPU Compatibility List for macOS
AMD APU Compatibility
1. Desktop Series
XIV. Radeon RX 500 Series
  • Supported Since: 10.12
  • Max Native Support: 13.x
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
Radeon 520​
NONONONONONONoNoNoNoNoNo
Radeon 530​
Lexa
Radeon RX 540​
Lexa
Radeon RX 550​
NONONONONONO
BaffinRadeon RX 550NONONONONONOYESYESYESYESYESYESYES
Lexa
Radeon RX 550X​
NONONONONONO
Polaris21Radeon RX 560DNONONONONONO
Baffin
Radeon RX 560​
Baffin
Radeon RX 560X​
Polaris20
Radeon RX 570​
Polaris20
Radeon RX 570X​
Polaris20
Radeon RX 580
Polaris20
Radeon RX 580X​
NONONONO
NO
Polaris20Radeon RX 590 GMENONONONONONOYESYESYESYESYESYESYES
Polaris30
Radeon RX 590​
NO
NO
I have a H470m DS3H, i5 10400 w/ RX 580 GTS XXX Edition. Everywhere I look, the RX580 is supported. BUT as much as the Mac OS (Sonoma)see it - in System Profiler and other apps; When I try to boot with it as the dGPU, I get stuck during start up with 'ApplekeyStore12195 operation failed' error message; the keep repeating, and it can't pass it. I need some help. What I'm I missing to be able to use this card.
RX 580 is supported OOTB. It might be possible that you may have the 2048SP version. Can you provide more details (vendor, device-ID, part number)?
I have a 2304SP model, attached is a picture(s), sry for being a little blurry (Windows 10 - works well in, Mac OS Sonoma - can’t boot with it)
XFX are problematic. You'll have to flash a different VBIOS.
lovos33
