Attached PR files.
It's a fun learning project,
the board is Supermicro X9SCA-F rev 1.01 with LSI 2008 SAS controller (old server)
I managed to install Monterey and got it running with Nvidia GT640 with OCLP patch, but was looking for something low profile as the case is low, hence this AMD R5 430 GPU. Seems like it will not work that well. Have a look, maybe you can suggest something. Thank you!
Attached PR files.
PR Files are missing.
Edited the post with PR files
I can't get this card
0x675b
I put 13.6 and above
R7/R9 cards are supported. Never tried an R5 and it may not be supported. What's the Device ID?
0x675b
Your profile shows you have HD7670. Is that what you're trying to make it work?
675B seems like an OEM card. You need to inject 6758 Device ID and it should work. If it doesn't, you may need to use OCLP to patch as the support may have removed. Check on HS first.
xxxxxxxxxx
