not working, I'm sure save changes and reset nvram
My config after use alldata method
Check the cable. Try to remove the HDMI Cable and Plug it again. Make sure you're not using any sort of Adapter.
i tried the typeC port it was successful, but the HDMI port seems to be receiving something but no screen is output
xxxxxxxxxx
