This is my EFI and ioreg
right ? but I don't know to need patch busID ?
oh, so I will patch con1 and con2 like that View attachment 5882
Your framebuffer patching isn't correct.
First, you need to identify the physical ports, then patch accordingly. In your case, the con0 is missing which is the Internal display.
i have 3 output ports for iGPU respectively: con0, con1, con2
Because of this, config framebuffer-portcount: 3
con0 is the port screen of my laptop because I see display0 inside it
Then I just config con1 and con2 to HDMI like that
And my port HDMI is 2.0 and my chipset is CFL, I need use LSPCON
--Summary my config about iGPU:
Do you think I'm wrong at any point?
felipepedrosa
