How to Activate Thunderbolt Bus on Alpine Ridge without Flashing Custom Firmware
Hello, any news on this? Also is this only for Alpine Ridge (not Titan Ridge) cards?
I can report success on my Lenovo Yoga 720 15-iKB Intel JH6540 Alpine Ridge 4C using edited SSDT-TbtOnPCH from here
IOREG and SSDT Attached.
Thunderbolt bus loads:
- Without TB Device at boot
- After one cold boot
- After two or more restarts from Apple Menu
- After sleep/wake cycle
- After hot plug.
Tested Working:
- Brydge/Henge Stone Pro TB3 Dock
- DisplayPort 1.4 to HDMI 2.0 Adapter
- Thunderbolt passthrough port
- TB3 Dock Audio
- Thunderbolt Ethernet between two macs
- Target Disk between two macs
- Clamshell mode
Issues:
- Requires two or more restarts or a cold boot to activate Thunderbolt bus.
- Requires display cable to be reinserted or one sleep/wake to turn on display connected to TB3 Dock when Thunderbolt Bus is loaded.
Update:
- Ensure to turn on Display before waking system up to avoid display not loading.
- No need to have bus activated, thunderbolt works acceptably without it. Just ensure all peripherals are plugged in at boot time.
1663809042079-png.5074
I can report success on my Lenovo Yoga 720 15-iKB Intel JH6540 Alpine Ridge 4C using ThinkPad SSDT-TbtOnPCH from here
- After hot plug.
Tested Working:
- Brydge Stone Pro TB3 Dock
- DisplayPort 1.4 to HDMI 2.0 Adapter (requires one sleep/wake cycle to turn on)
- TB3 Dock Audio
Issues:
- Requires one Sleep/Wake cycle to turn on display connected to TB3 Dock when Thunderbolt Bus is activated.
Good for you... I wish it is possible for my titan ridge card.
@i0ntempest There is a wealth of information in this thread.
Hopefully you can salvage something for your card 👍
For Titan Ridge, flashing Custom Firmware is required. However, if you do not have any specific Bus usage, you can have the HotPlug without the Bus.
Hi, has there been any further development? Since I am working hard on this exact issue, maybe you can share your findings so far via direct message?
kind regards
-cuemaxx
Yes, only for Alpine Ridge.
can you tell me that JHL6340 can do it
Is compatible and can work.
jonnyrec
