Then how to create a bootable usb?
It's already covered in the guide.
There is nothing mentioned after saving config.list file. Like where to place the EFI folder and how to make the USB bootable
It's already included in the guide. Read carefully.
I have. But got lost after the instructions in config.plist
At which step are you stuck? You should create a dedicated thread to tackle all of the issues you have. This thread is specifically about NVIDIA WebDrivers.
I completed that part. After that blank. Look screenshot
I didnt get this part. Where to place the EFI folder.I placed it in the same parition as the apple recovery boot folder and i tried to boot that USB> But its not even opening the open core boot screen.
To install the OpenCore, copy the EFI to the ESP. That's it.
Without a Bootloader, the system cannot find a Bootable USB, therefore, it cannot boot.
Did you placed the EFI folder?
rayd8
