would a gt 730 (fermi) work
and would a quadro p400(pascal( work?
With OCLP, it should work.
Quadro 4000 is supported. On higher version, OCLP should do the job.
Yes exactly where i created the apple folder at first
Create a separate thread and we can get in there more better. Once you create the thread, provide the directory structure of the USB.
Hello,
Would it be possible to have dual display working? I mean a display port and HDMI.
Could you please explain how? I currently have Monterey working with this guide on a single display (display port), but I have no signal on the HDMI port.
No PR files attached. Provide the exact product link for your GPU.
There is a known issue with the Pascal GPUs.
Alisson de Santana
