after patching many applications that I download stopped working like discord and final cut pro although chrome and all are working fine any fix please help me
Add ipc_control_port_options=0 to your boot args.
Stuck at IOConsoleUsers: gIOScreenLockState 3 after patching. Nvidia GT 1030, Monterey. Attaching my EFI.
What display connection are you using?
Both HDMI and DVI. There can be a problem with that?
HDMI should be fine.
after patching screensshare is not working for me apps like discord, Teamviewer and other screen-sharing apps show a purple screen. If anyone will help me help is appreciated.
already done that but not working
my boot args
-v alcid=12 watchdog=0 agdpmod=vit9696 dk.e1000=0 e1000=0 keepsyms=1 amfi_get_out_of_my_way=0x1 ipc_control_port_options=0 ngfxcompat=1 ngfxgl=1 nvda_drv_vrl=1
my boot args
raymondleung416
