can anything be done?
Also, is IGPU factory disabled on this Laptop?
Yes. There's no iGPU
Then it should work.
The last step, after restarting, it went to recovery mode directly.Here is my EFI. My device: Asus Tuf Z390 gamming wifi + i9-9900k + 1050Ti.
Is there anyone who can give me your perfect EFI, i'll be appreciated.
You need to set the default Boot Volume.
Hi,
is my configuration compatible with it? i just tried this but for Ventura..... and after the root patch my pc restart always in recovery mode XD(I was convinced that my gpu was compatible with ventura)
now i wanna try it for Monterey. Here is my EFI. Can u setup it for monterey if there is something to change?
Hi,
This patch is purely experimental and should not be used production machines.
No problem.I know that but i read that this patch work only on kepler gpu and not pascal. Is it true?
No, that's wrong. It can be used for Pascal GPUs but still its an experimental work and is not meant for production usage. You should consider reading the guide again.
there's no one example online with a pascal gpu working on monterey
khoi
