Your profile is incomplete. Fill your profile first.
Done.
Btw, I forgot to ask if I have to copy any kext to /S/L/E(old skylake Intel) in addition or it works only with the Kaby Lake which are already included?
Done.
No, you don't need to copy any such kexts.
Here we go
  • EFI-suizman.zip
  • PR.zip
Here we go
As the Clover guide is not up to date, I would recommend you switching to OpenCore.
Thanks, I've switched to OC and now the driver is loading. But I'm facing other issue 😢
I'm unable to get 1440p to work over HDMI. It's wired because it seams that the OC boot screen is actually running 1440p but when the system finish booting the maximum available resolution is 1080p in the display settings.
I'm using enable-max-pixel-clock-override and max-pixel-clock-frequency properties.
I've already tried to manually generate the EDID but get the same result.
  • EFI-suizman.zip
Just switching to OpenCore isn't sufficient. You clearly did not followed the guide properly.
Hi, I've managed to make it work with OC. Now I have the iGPU working and also I'm able to get 1440p output with the HDMI.
The problem was that I was using framebuffer-patch-enable, framebuffer-stolenmem, framebuffer-fbmem and also that my monitor is 240HZ with FreeSync and I have to force it to run at 144 which is the maximum for HDMI at 2K.
This is my working config for Skylake. Sure I need to improve it to make the USB3 work and all that stuff, but at least now I have a properly working desktop environment.
Many thanks!
  • EFI-Skylake-iGPU-UHD.zip
Many thanks!
Great!
This guide helped me a lot. Thank you so much!!
Trending Threads
amsva011002
