I repeated all the steps again. Found an error - invalid value AAPL,ig-platform-id
After changing to 00001259, Hackintosh boots into a black screen and completely stuck, even no ping.
I am attaching the updated EFI folder and last Kernel-2034-09-03-110854.panic.
Provide Hackintool>PCIe Export.
Why does it show HD620? Cause in my current temporary config AAPL,ig-platform-id=00001B59 (LVDS works)
Provide the current EFI and the IOReg. Double check to make sure everything is as per post #48
Current EFI of course different.
The EFI that I did according to your recommendations in post 48 is not possible to boot into the GUI and, accordingly, it is impossible to provide data
Then provide the one you configured as per post #48. You can boot using whatever you're able to.
alexito
