Problem Reporting Files.
Con0 port is not defined. How many video ports are there on the system?
Connector 0 is LVDS with internal display connected (I think so cause I see in IORegistry - see screenshot) Screenshot 2022-08-21 at 00.40.40.png
When I connect HDMI cable in system.log appears :
default 00:43:13.896442+0300 kernel [IGFB][LOG ][DISPLAY ] [Hot_Plug] FB-1 port = 1 at 519856842
default 00:43:13.896452+0300 kernel [IGFB][LOG ][DISPLAY ] [Hot_Plug] isHPDLow = 0 emptyDongle = 0 sinkCount = 0 sinkCountChanged = 0
default 00:43:13.896456+0300 kernel [IGFB][LOG ][DISPLAY ] [Hot_Plug] Event insert
default 00:43:13.896481+0300 kernel [IGFB][LOG ][DISPLAY ] [Hot_Plug] FB-1: Hot plug on port1
default 00:43:13.896495+0300 kernel [IGFB][LOG ][DISPLAY ] [Hot_Plug] AGDC managing Display: Start listening to AGDC
default 00:43:13.896704+0300 kernel [IGFB][LOG ][DISPLAY ] [AGDC] Port enable
default 00:43:13.896776+0300 kernel [IGFB][LOG ][DISPLAY ] [AGDC] Get stream AUX access read for agdc port 2 stream=0 : address=0, size=1
default 00:43:13.896780+0300 kernel [IGFB][ERROR ] [AGDC] FB pointer was NULL. Returning
default 00:43:16.125123+0300 kernel [IGFB][LOG ][DISPLAY ] [AGDC] Get stream AUX access read for agdc port 2 stream=0 : address=0, size=1
default 00:43:16.125138+0300 kernel [IGFB][ERROR ] [AGDC] FB pointer was NULL. Returning
default 00:43:16.125140+0300 kernel [IGFB][ERROR ] [AGDC] Failed with status e00002bc for stream access aux
default 00:43:16.135855+0300 kernel [IGFB][LOG ][DISPLAY ] [AGDC] Port enable
default 00:43:16.816687+0300 kernel [IGFB][LOG ][DISPLAY ] [Hot_Plug] FB-1 port = 1 at 522777084
default 00:43:16.816698+0300 kernel [IGFB][LOG ][DISPLAY ] [Hot_Plug] isHPDLow = 0 emptyDongle = 0 sinkCount = 0 sinkCountChanged = 0
default 00:43:16.816701+0300 kernel [IGFB][LOG ][DISPLAY ] [Hot_Plug] Event remove
default 00:43:16.816709+0300 kernel [IGFB][LOG ][DISPLAY ] [Hot_Plug] FB-1: Display unplugged from port1
Connector 0 is LVDS with internal display connected (I think so cause I see in IORegistry - see screenshot)View attachment 4926
Your profile indicates that you're using a Desktop. So are you using LVDS port on that?
Are you using Ventura?
You cannot expect it to work as none of the connectors are defined. I already mentioned to define con0, con1 and con2.
I use Ventura
that's why I'm asking for help to correctly identify the connectors, because on my own I can't
I use Ventura
Remove the following keys
-AAPL-slot name
-device_type
- model
Define the connectors with the help of Connector patching
You just need to define 1xLVDS for con0 and 1xHDMI for con1
ANARKRUTOI
