Kpbicka
- Aug 20, 2022
- Lenovo IdeaCentre 510
- Intel® Core™ i3-6100T 3.2GHz SkyLake
- Intel HD530
- 14.x
Connector 0 is LVDS with internal display connected (I think so cause I see in IORegistry - see screenshot)Problem Reporting Files.
Con0 port is not defined. How many video ports are there on the system?
When I connect HDMI cable in system.log appears :
default 00:43:13.896442+0300 kernel [IGFB][LOG ][DISPLAY ] [Hot_Plug] FB-1 port = 1 at 519856842
default 00:43:13.896452+0300 kernel [IGFB][LOG ][DISPLAY ] [Hot_Plug] isHPDLow = 0 emptyDongle = 0 sinkCount = 0 sinkCountChanged = 0
default 00:43:13.896456+0300 kernel [IGFB][LOG ][DISPLAY ] [Hot_Plug] Event insert
default 00:43:13.896481+0300 kernel [IGFB][LOG ][DISPLAY ] [Hot_Plug] FB-1: Hot plug on port1
default 00:43:13.896495+0300 kernel [IGFB][LOG ][DISPLAY ] [Hot_Plug] AGDC managing Display: Start listening to AGDC
default 00:43:13.896704+0300 kernel [IGFB][LOG ][DISPLAY ] [AGDC] Port enable
default 00:43:13.896776+0300 kernel [IGFB][LOG ][DISPLAY ] [AGDC] Get stream AUX access read for agdc port 2 stream=0 : address=0, size=1
default 00:43:13.896780+0300 kernel [IGFB][ERROR ] [AGDC] FB pointer was NULL. Returning
default 00:43:16.125123+0300 kernel [IGFB][LOG ][DISPLAY ] [AGDC] Get stream AUX access read for agdc port 2 stream=0 : address=0, size=1
default 00:43:16.125138+0300 kernel [IGFB][ERROR ] [AGDC] FB pointer was NULL. Returning
default 00:43:16.125140+0300 kernel [IGFB][ERROR ] [AGDC] Failed with status e00002bc for stream access aux
default 00:43:16.135855+0300 kernel [IGFB][LOG ][DISPLAY ] [AGDC] Port enable
default 00:43:16.816687+0300 kernel [IGFB][LOG ][DISPLAY ] [Hot_Plug] FB-1 port = 1 at 522777084
default 00:43:16.816698+0300 kernel [IGFB][LOG ][DISPLAY ] [Hot_Plug] isHPDLow = 0 emptyDongle = 0 sinkCount = 0 sinkCountChanged = 0
default 00:43:16.816701+0300 kernel [IGFB][LOG ][DISPLAY ] [Hot_Plug] Event remove
default 00:43:16.816709+0300 kernel [IGFB][LOG ][DISPLAY ] [Hot_Plug] FB-1: Display unplugged from port1
