plz help me enable Intel AC-3165 on lenovo v-110 15ISK
Nikos365
Levovo V-110
intel i3 60060U
intel Graphics 520
10.14.x
Hello, I have installed Catalina on Lenovo v-110 but the wifi does not work.
Could you help me enable it?
thanks
thanks
Post a output of Hackintool>PCIe.
i want to enable it not to find the PCI root. See the header of the post
Hello I did not manage to get wifi work either Bluetooth
My wifi adapter is an intel 3165
Here is my PCIe list and my config.plist just in case somebody needs it to read it
I tried the above method but without success
Provide IOReg, EFI folder and kextcache output.
there are the files
EFI folder is too big so I have put it in google drive folder:
there are the files
Unfortunately, your WiFi Card isn't from Intel. It is RTL8821AE, which is not supported at all. Replace with a compatible card instead.
What about Bluetooth?
J.An
