plz help me enable Intel AC-3165 on lenovo v-110 15ISK
any other card that can fit the m2 slot? plz!!
is there a list of brands for m2 BT/WIFI cards?
The wifi card and the Bluetooth is one card? do I have buy 2 cards?
Depends on several factors, one of them is Whitelist.
Although, newer ones don't have, but you cannot know unless you try to install one.
Read WiFi and Bluetooth section
I have the same Intel 3165 built-in card (0x8087 0x0A2A) and it works on Monterey 12.6. You need these 3 kext:
AirportItlwm.kext
BlueToolFixup.kext
IntelBluetoothFirmware.kext
AirportItlwm.kext
BlueToolFixup.kext
He is having Realtek WiFi/BT which is completely unsupported.
Hmm, does it means my Intel 3165 having Broadcom BT ?
That sounds kind weird. The WiFi can be checked using Hackintool>PCIe and the BT can be checked using Hackintool>System>Peripherals.
You can also check it via System Report>Bluetooth and USB section.
It could be possible that the reason why you see Broadcom is due to the loading of the kext.
If you check the PID and VID, it's from Intel.
what card could be an alternative to RTL8821AE to fit with my laptop Lenovo v110 15isk mainboard?
This card comes in two variant. Half mini PCIe and A+E Key Type. Provide a picture of your WiFi Card to confirm that.
Roberto Sales
