TomCraft
- Apr 17, 2022
- X99
- E5 2680v4
- RX 6800 XT
- 10.13.x
Use the following command in Terminal and export it as Text.
sudo kextcache -i/
Also, what cable are you using for Display?
~ ❯ sudo kextcache -i/
kmutil done
I'm using DP cables on both of my monitors.
The issue appears also on both monitors.
