GixxerJ
- Oct 27, 2021
- Gigabyte Z590 Aorus Master
- Intel I7 11700K
- XFX MERC 319 RX 6900XT
- 10.13.x
Thanks! I'll check that out if the Z590 doesn't work out.This might help you
Setting up Docker instances to run on an AMD-based macOS Mojave Hackintosh without Hypervisor.framework :: Kittywhisker's Nibbles
One of the biggest gripes I've had with macOS, aside from the inability to run Team Fortress 2 is the inability to use Docker instances without having to resort to using VirtualBox, which for some reason provided degraded performance on my system. After the excitement and disappointment from...kittywhiskers.eu
Awesome - I had read through dortania's guide and didn't see that, this is good news!Works perfectly with absolutely zero issues. Yeah, a compatible GPU is required only.
And I already have the GPU set up from earlier!
Thank you!
		 Any guide you recommend for the Z590?  (I had started to run into difficulty figuring out what to use around the ACPI section of the guide I had followed earlier)
