This might help you
Thanks! I'll check that out if the Z590 doesn't work out.
Works perfectly with absolutely zero issues. Yeah, a compatible GPU is required only.
Awesome - I had read through dortania's guide and didn't see that, this is good news!
And I already have the GPU set up from earlier!
Thank you!
Z590 works like a charm!
Since you haven't steered me wrong yet.... :) Any guide you recommend for the Z590? (I had started to run into difficulty figuring out what to use around the ACPI section of the guide I had followed earlier)
Depends on what Z590 hardware you have.
Hey Guys, I have a "random pixel" issue with my RX 6800 XT on macOS 11.6.5 Big Sur.
Two weeks ago this pixel started to appear everywhere.
I made a screen recording of it:
This random pixel appear all over the place in MacOS GUI very random and sometimes a lot and never stopping.
In the screen recording I found a way to reliable reproduce the issue.
I tested the GPU in Windows and it works flawless no random pixel issues in the GUI or Shadow of the Tomb Rider Benchmark;
Shadow of the Tomb Rider Benchmark in MacOS also has no issue with radome pixel at all.
GFXBench on macOS, which runs Metal benchmarks produces a lot of random pixels in the tests.
I had an old disk image dumb lying around from 8 month ago of my macOS. After booting it, the same pixel issue was also present there so I can rule out any update related issue.
I tested also a RX 580, which works without any issues in my macOS.
So I narrow the issue down to something with GPU and macOS/Metal related.
Anyone has advice how to proceed?
This is weird. Provide PR files to check further. Include your Card and macOS details.
Thanks for the quick replay, I attached my PR.
(Sorry, I don't know how to get kextcache output)
asrock AMD Radeon RX 6800 XT Taichi X 16G OC
Use the following command in Terminal and export it as Text.
sudo kextcache -i/
Also, what cable are you using for Display?
Similar threads
Umbreon
