When i create a Ioreg the file as 28,7 Mb, to much to upload. Heaven zip has 8,2 Mb.
That's too large. Check the guide.
How i can produced the Kextcache output. Don´t know how!
It's already mentioned in FAQ. Use the following command in the terminal and export it to text.
sudo kextcache -i/
The Kext are missing because the compressed folder was to big as I said before.
Use external link.
The folder drivers has 3 files, note the HFSPlus.efi, because my system didn´t boot with this one, as I told you before.
Other drivers are missing as well. If the system is not booting, you should attach the verbose video along with the PR files.
Here are some of the issues
Drivers directory is still missing important drivers.
Remove Off folder from the kexts directory.
Remove FakeSMC sensors kexts.
sudo kextcache -i/
Use external link.
I again i installed the clover again i think i was missing one file FSInject.efi. Now the system is booting with HFSPlus.efi.
I have collect all the files. Check please. But The black screen after booting is something that happens sometimes.
I have read some texts on GitHub and on this site about intel UHD 630, and i have made some modifications on my config.plist, so tell me is correct to do this, or it´s necessary to return to previous settings. I send you 2 screenshots and the modified config.plist. Now the information about the UHD 630 is different, but don´t really know if this this correct?
I only send the modified files and new screenshots, because the other files are the same as the last post.
Still, important drivers are missing. Check the installation guide.
Looks good. :)
That´s odd because i have made the installation of clover several times and does not install me more files, can you please tell me what files are still missing and don´t see them on the installation guide, on the guide you said " The rest necessary drivers will be installed automatically by default.", but never get more files. It´s strange (can you show-me the list of files I need please!).
Thank you for your attention.
I have add a list of files i have installed just now. it´s on the zip file, tell-me if it´s okay now. The tools folder (it´s necessary?)
Here is the list of drivers.
  • ApfsDriverLoader.efi
  • AptioMemoryFix.efi
  • AudioDxe.efi
  • DataHubDxe.efi
  • FSInject.efi
  • HFSPlus.efi
  • SMCHelper.efi
Reactions: saitam
  • AudioDxe.efi
  • DataHubDxe.efi
  • FSInject.efi
  • HFSPlus.efi
  • SMCHelper.efi
Thank you.
Can you tell me if the list of all folders is this one?
I have seen people using a folder called BIOS inside the drivers folder.
Thank. You- Now everything is working but as I told you sometimes when the system boots, i have black screen. Is there a reason?
mulineee21
