That's too large. Check the guide.When i create a Ioreg the file as 28,7 Mb, to much to upload. Heaven zip has 8,2 Mb.
It's already mentioned in FAQ. Use the following command in the terminal and export it to text.How i can produced the Kextcache output. Don´t know how!
sudo kextcache -i/
Use external link.The Kext are missing because the compressed folder was to big as I said before.
Other drivers are missing as well. If the system is not booting, you should attach the verbose video along with the PR files.The folder drivers has 3 files, note the HFSPlus.efi, because my system didn´t boot with this one, as I told you before.
Here are some of the issues
Drivers directory is still missing important drivers.
Remove Off folder from the kexts directory.
Remove FakeSMC sensors kexts.
