Hello i have a problem with the configuration of the UHD 630. IF i follow the guide i have acceleration, but not 3440x1440 resolution
What resolution you get after fixing the Graphics?
Attach your complete PR files.
Hi again.
i Have fixed the problems with the resolution and the acceleration (have transparency on the bottom bar, and clover configuration menu for as example.
Now the problem is with the shutdown. The computer don´t shutdown. There is something odd. If I remove the efi folder on my computer and install clover Clover_r5118, as new boot system. i can´t boot my system with my good config.plist. Do you know why? I have send pictures about.
I can´t upload the zip. i send link for the google drive
Hi again.
https://drive.google.com/file/d/1q2pZOsCa57fs4VQE9f8ZUFOu02x4tix0/view?usp=sharing
NVRAM is not working which is causing issues with Shut Down and probably, sleep/wake too. For the Clover, make sure you use the kext and config.plist along with the drivers which are overwritten by Clover.
What should i do, then? Explain i have some difficulties in that area!
Hello again it is enough to press the F11 keys on clover boot?
Is the config.plist ok, for my UHD 630?
Incomplete PR files attached. IOReg and kextcache output is missing.
Remove other folder from Clover/ACPI/patched.
With Desktops, i don't suggest to use UIAC. So remove that.
Necessary renames are missing from your config.plist. For more information, read here:
Change the SMBIOS to iMacPro1,1.
The drivers directory is not as per the guide. For more information, read here:
Kexts are not as per the guide. Follow the above linked guide.
Once you fix the above issues, reply with new files.
I´m changing the configuration, making a new install and following all the guide. Can i use the last version of clover directly? or should i use the one mentioned on he guide?
The installation is for Mojave not Catalina, not yet because i need to work with some software that are no version to Catalina yet, maybe on the 3 or 4 quarter of 2020.
One question on the section graphics, should i used (0x3E980003) because you told me to use the SMBIOS iMacPro1,1?
With the new clover the UEFI drivers does not have this name drivers64UEFI, correct?
Good.
Yes, use the latest Clover version from the downloads section.
You can use Mojave. Use 10.14.6
Don't make any changes for the Graphics. Firstly create a proper configuration which can boot your system and is stable and then continue to fix issues.
Yes, i suggest you to use iMacPro1,1.
Yes, correct.
Thanks for your help.The system is installing. I had to put the fix for limit port USB, the system stopped.
But now I´m installing. with this config.plist.
On the uefi drivers i only have AptioMemoryFix-64 and ApfsDriverLoader-64 and HFSPlus.efi.
On KEXT only the five mentioned on the guide (of course with the sensors).
The installation is finish trying to load from the disk where i made the installation but i have this message [IGPU] Graphics driver failed to load: could not register with Framebuffer driver!
ryusuke17
