I've fixed the issue, as well as my audio problem. The two problems I have left are that I cannot change the brightness and I cannot see the battery percentage of my laptop.
please how
Hi, I have followed the guide and I'm still getting the IGPU Graphics drive failed to load on screen but I don't see it in the debug.log. I also see a Applekeystore failed on the screen. The laptop boots to the log in screen and I can log in but it crashes after a few seconds.
I struggled to find any of the options mentioned in the BIOS.
Incomplete PR files attached.
The configuration is not upto the mark. Start here:
OK, I've started from scratch again. I'm getting a lot written to the screen but no debug log in misc directory.
Process is freezing at this point in the screenshot.
Enable "change EC0 to EC" patch in your config.plist.
Attach your new EFI.
Made the change - no difference. I am trying to boot rather than get the installer up.
EFI zip attached
I've removed themes and the tools directory to reduce the size.
EFI zip attached
It's still not upto the mark. Following are the issues.
  • config.plist is corrupted.
  • BIOS directory must be removed.
  • You're using two drivers. Only use AptioMemoryFix-64.efi.
Fix the above issues and attach the new files.
In what way is it corrupted? How do I resolve?
I've done the other 2 things and it's still the same.
Remove all the config.plist. Copy the new config.plist again. Make sure you read the Notes.
Attach the new EFI.
Boot using Fake ID and attach a kextcache output.
Similar threads
alvarg82
