How do I get the IOReg and Kextcache output, also wouldn’t it make more sense to use the UHD 630 config as the other one is for HD 620 not UHD 620.
I have followed the guide again, this time I used the latest Clover, latest version of the kexts, included IOReg, included kextcache output and I have also included the config for HD 620.
I've made progress, it boots into the installer however my problem is that the screen is flickering.
Replace OsxAptioFix3Drv.efi with AptioMemoryFix64.
There are duplicate and unnecessary kexts in L/E. Remove all of them.
Attach the new files.
I've fixed the issue, as well as my audio problem. The two problems I have left are that I cannot change the brightness and I cannot see the battery percentage of my laptop.
Reactions: hackint1247
No PR files attached.
Similar threads
alvarg82
