Limitations
Desktop APUs
XVIII. Lynx (Liano)
  • Max Native Support: 13.x
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Virgo (Trinity)
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
HD7660D
XVIII. Richland
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
8570D
8650D
8670D
XVIII. Kabini
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Kaveri and Godavari
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Carrizo
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Bristol Ridge
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Raven Ridge
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Picasso
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
1 more thing can i use my AMD Ryzen™ 7 5800H & RX 6600M pc
Minisforum HX80G on tahoe ?​
can i use my
Minisforum HX80G AMD Ryzen™ 7 5800H & RX 6600M on tahoe ?​
Hi so i can use
ACEMAGIC AMD Ryzen 7 5700U with vega 8 on Tahoe ?​
Good morning, I'm interested in purchasing a mini PC with an AMD CPU. Which of the latest models would be compatible? Beelink Ser 5 Ryzen 7 6800U, NiPoGi AM06PRO Mini PC Ryzen 5 7430U, Acemagician Kron Mini K1 Ryzen 4300U?
Thanks
Nic
Thanks
Nic
Last two are supported.
chirag11122
