Ventura - Broadcom BCM94360CS2 Wifi not working
thongnguyen1809
Lenovo Legion 5 15ACH6
AMD Ryzen 5 5600H
AMD Radeon Graphics | NVIDIA GeForce RTX 3050
Hi all, I have just bought a BCM94360CS2 wifi card + an adapter to convert to M2 A+E key slot for my Hackintosh laptop running Ventura 13.7.8 + Windows 11.
The card is fully functional on Windows with working wifi and bluetooth, but on MacOS, only Bluetooth is working. The wifi icon shows an exclaimation mark and can't be turned on.
I expect that this card will work natively so I have already removed the kexts for Intel wifi and their entries in the configs.
I have attached PR and my OC EFI for the laptop below.
Hope this can be solved!
The kexts doesn't seem to load at all. 43a0 is a native ID and should work fine.
Try to add AirPortBrcmFixup and then check. If it fails, check the guide below:
Hi, i've tried using AirportBrcmFixup but it did not work. I dont think the problem is hardware as the card also works on Ubuntu 24.04 after installing drivers
I dont find any PS0 in my dumped DSDT from maciasl. I have attached below the DSDT for GPP4.
The only thing that I have done was renaming from WL00 to ARPT, adding tag of model, compatible, built-in in Opencore
Attach the native ACPI dump to check and include a copy of EFI as well.
Here are the SSDTs and DSDT dumped from Ubuntu, my clean EFI, also some log related to airport and ioreg if you need
Add the attached SSDT and then reply with IOReg.
gopon_user
