Broadcom BCM94352Z (DV1560) not working on Ventura
mirenos
B365M DS2V/Lenovo Ideapad S340-15API
i5 9400F/AMD Ryzen 5 3500U
RTX 2060 Super/Radeon Vega 8
Hi everyone, first post here (besided saying hello). I'm woking on a side hackintosh project myself first time with my Lenovo Ideapad s340-15API, I fresh installed Ventura, using Opencore and following EliteMacx86, Noot and Dortania guide.
So far I noticed a coupe of problems, but make me annoy the most its the Wifi card not working at all, even I tried to add AirportBrcmFixup.kext kext in the kext folder, removed AirPortBrcm4360_Injector.kext from config.plist, and left AirportBrcmFixup and AirPortBrcmNIC_Injector entries in the kernel list.
Do you have any suggestion on something else to try before ordering a new WiFi/BT card?
In that case which card do you recommend to run Ventura on my system (pls im dont want to change, runnin out of cash)?
Thanks a lot!
Hope everyone have a nice day!
Thanks a lot!
It seems like the kext is not being attached.
Remove brcmfx-driver=2 from boot args. Reset NVRAM and then attach a copy of IOReg.
orggnteng
