Ventura - BCM94360cs2 wifi not working
kathir
GB: z390i Aorus Pro Wifi
i5-9600k
iGPU
Hi, Suddenly wifi not works , but BT works fine.
This issue started after update after 13.6.1
I have checked connections of card, re-fixed after clean. USB port mapping newly again. still not working.
PR file attached, Appreciate your support.
The Card isn't detected. So the card could be faulty or has not been installed properly or it is turned off from BIOS. Verify using Hackintool>PCIe.
김영재
