Hackintosh Post Installation Problems Sequoia
Asus h110m-c
i3-6100 with intel hd 530
Nvidia gt 730
15.x
Hello everyone. I have had a hackintosh with Sequoia installed for months.
my pc configuration is:
intel i3-6100
16gb of ram
gt 730 2gb video card
everything works great, I can't complain except that if I don't use the pc for a while and I go to use it I find it completely frozen and I have to force restart it. I checked my plist, disabled hibernation, screensaver or stand-by (all disabled) can you help me understand what it could be? thanks in advance
intel i3-6100
16gb of ram
Attach your EFI to check!
Also, note that NVIDIA is completely unsupported, and the support is experimental. The i3-6100 has IGPU and it can be patched and should be more stable than using the NVIDIA.
I use the PC for graphics and I can't use the igpu. everything works fine I don't understand why it freezes when I don't use it for a while. I'm attaching the efi. I'll start by saying that I used opencore legacy patcher to patch my nvidia
yesterday it froze for the umpteenth time after I left it to go shopping. I found it completely frozen and with many lines on the display
The EFI is not as per the guide. Here are a few issues
Remove the patch from ACPI>Patch section
Remove the following boot args: dart=0 igfxonln=1 darkwake=0
sorry for my ignorance. what is PR files?
nothing to do it continues to fizz even if you leave it still for just 10 minutes
Hi, the problem is starting to become more frequent than usual. Can you help me solve it please? Without giving up the dedicated video card?
Are you using NVIDIA or Intel IGPU?
ryusuke17
