SOLVED Open core and Monterey Installation problems
Why are you using USBInjectAll and UTBMap together? Use USBInjectAll as per the guide and map the ports during post installation.
Also, you must add -igfxvesa in the boot arg.
IgnoreInvalidFlexRatio is required for BDW and older.
everything went well finally, only now I have an absurd lag, it goes jerkily, I have no audio and then I would like to ask you how to enable my gt 730
Nice. You see? You just need to follow the guide exactly. When you did, you got it installed!
What macOS version did you install?
Bene. Vedi? Devi solo seguire la guida alla lettera. Quando l'hai fatto, l'hai installato!
Quale versione di macOS hai installato?
yes thanks for your detailed guide. i currently have monterey but i would like to get to sonoma.. only i cant patch my igpu and i would also like to activate my nvidia gt 730, but OCPL tells me there is nothing to patch. can you help me?
Firstly check if your NVIDIA is GK208 variant and as the original issue is resolved, this thread will be closed and you'll have to create a new one for the other issues you may have.
How do I view the variant?
I couldn't do an automatic update (via settings) Because from the settings it didn't give me any update I don't know how. but I had to update manually by downloading the dmg of sonoma Changing smbios. Now everything works great and you can close this thread. Thank you very much for your help
Glad to hear!
Reactions: Innovatekgalatina
dmitriy103
