Yes, its compatible and it works with TRIM. The highest version we tested is macOS Monterey. The higher series 3400 is also supported as well.I saw the OEM section and I found out that there were a few tested in there which works with Mac. I do actually have a Micron 2450 with me but it’s in a backup mini-PC that I use when I travel or lodge. Can it work with TRIM enabled? Also, up to which Mac version will it work?
Likely possibleReason why I’m asking is that the whole root of the problem in my case is probably the NVME drive. My Chinese SSD might also be incompatible as well hence why it freezes. Also read that the Phison NVMes (Sabrent Rocket) ain’t viable anymore since Monterey.
That's also an option.At this point I don’t mind being stuck with Catalina or High Sierra as long as I have this working with a compatible drive.
Maybe you can backup the data from Micron 2450 and use it to install and once installed, you can definitely buy a good drive.Please advise, thank you.
Should be supported. SN770 is dying like crazy, even on Windows side. Never liked the SN770. Tons of users had problem. Seems like the SSD in your Laptop is 2230?Edit: already bought a WD SN740 and I'm already waiting for it to arrive before I continue this. Read that it shares a lot in common with SN770 with its WD controller and other specs, with the difference being the tolerances. Since some WD drives are more compatible with running Mac, especially the ones with the WD Controllers, I just decided to take one instead of risking to brick this spare M. 2 drive that I have.
