Apply GFX0 to IGPU rename
Apply HECI to IMEI
Apply MEI to IMEI
Enable -disablegfxfirmware in bootargs
Reply with new PR files.
Please check the file attached
Sorry, forgot about gfx. one moment
Apply HECI to IMEI
Apply MEI to IMEI
Another try, sorry, a bit tired )
No worries. It happens. I'm also about to signoff. Long day and coding stuffs.
Okay, so the Device ID is not natively supported.
Install latest FakePCIID and FakePCIID_Intel_HD_Graphics.kext to S/L/E.
Is it really necessary to install in s/l/e? Why not in clover? I observed them working ok from clover c/k/o.
What about weg? Shall I remove it?
I prefer FakePCIID installation to S/L/E. Of course it can be installed to CLOVER/Kexts/Other.
No need to remove WEG. Keep that and also install both the FakePCIID.
Reply with new files.
Well, I can simply return a package from ssdt dsm, no need to use fakepciid if there's still weg, I suppose.
Like this code in the IGFX _DSM observed on my real mac:
So, in my _DSM I can just
              Return (Package()
                    "model", Buffer() { "Intel UHD 620" },
                    "AAPL,ig-platform-id", Buffer() { 0x00, 0x00, 0x16, 0x59 },
                    "device-id", Buffer() { 0x16, 0x59, 0x00, 0x00 },
                    "hda-gfx", Buffer() { "onboard-1" },
For all UUIDS, except wintel's 3E5B41C6-EB1D-4260-9D15-C71FBADAE414
But ok, I did not succeed, so will follow your instructions, thank you!
Do I need to enable injection in some other way? It does nothing without it.
              Return (Package()
I still prefer FakePCIID method. No any other way to inject except DSDT and Kext.
Attach your new PR files asked in this post
Sure, this is dsdt.
Ok, doesn't matter, but my question was - do I need to change clover's config prior to sending you files? Because I just put both fakepciid back and observe no changes. And it shall be so since no injections are configured in clover. I can send you files as they are now but I suppose without igpu properties injection, they are the same as I sent you before?
I've got a "conversation" from you but cannot answer - there's no "reply" button or something alike (
Please help!
Please help!
Check now.
Similar threads
alexito
