Well, looks like you forgot what i said for Graphics. I'll mention the issues below.
Remove all the Acpi patches from Clover except Audio renaming.
Remove "Debug" from clover.
Remove slide=0 and -disablegfxfirmware from the bootargs.
Remove debug from boot tab in Clover.
Remove Intel GFX
Remove Inject Intel and the ig-platform-id
Remove the patched and unpatched DSDT and SSDTs from ACPI folder
Remove the DSDT from ACPI/patched
Remove FakePCIID kexts from Clover/kexts
Install WhateverGreen kext
After doing the above process, empty your trash and rebuild the kextcache.
Reply with new PR files.
Sorry, misunderstood you. Here it is. I have just 32 and 64 dvmt in bios, so have 31m in macOS without properties for weg or clover's injection.Hope now it's ok. Thank you!
Change the DMVT to 64MB. If possible, provide me the screenshots of each menu and tab from BIOS.
I asked to remove the Acpi patches except Audio which is HDAS to HDEF rename.
Enable the Audio rename
Next time you run kextcache, make sure you attach the full output from the terminal.
Also, what are you using for Display? HDMI or Display port?
The dvmt is 64m, it does not load os at all without patches if set to 32, as described in the weg docs.
There are just a few settings, I made a photos, they're in the attachment.
I returned back hdas-hdef rename and have the same result with sleep/wake. Do I need to post files again?
This is the full kextcache's output, I did sudo kextcache -i / > kext.txt:
viktor@Viktors-Mac-mini:~ $
viktor@Viktors-Mac-mini:~ $ sudo kextcache -i /
Password:
KernelCache ID: 01BF6766F80246A25F8346A996F31FFD
viktor@Viktors-Mac-mini:~ $ sudo kextcache -i/
Password:
I use HDMI, my minidp to dp cable does not work - screen is blinking even in bios.
Thank you for your help!
Okay.
Yes, but not all of them are attached. Attach all the image from Advanced tab.
Please note that we're still working on the files and configuration to make things perfect. Once we do all these, we can test the "sleep/wake" and verify
Yes, that's what needed to be in text. But it's good that you attached.
Okay.
Okay.
Okay.
There's nothing interesting really, everything is as usual for hackintoshes. But you do not need to believe me, no problem, I attached all of them, one by one.
As I told you before, I spent a lot of time trying to make it work with no success, so I really have no words to express how grateful I am! Thank you very much! I hope you could help me with it.
It's good that you follow the instructions.
Hopefully, we can fix it.
Enable XHCI Handoff to Enabled. Save & Exit BIOS.
Boot and attach new PR files.
Do I need to attach everything or just ioreg, because nothing else has changed?
No problem, here they are:
Apply GFX0 to IGPU rename
Apply HECI to IMEI
Apply MEI to IMEI
Enable -disablegfxfirmware in bootargs
Similar threads
alexito
